Hi Folks,
I recently updated a form on a page that was originally created in a Freeway Pro version before the “Send Form” page action item was available. I’ve since converted the page over and it appears to work correctly. However, I’m not seeing pretty much any of the "Input/Field items options that appear on page 199-200 of the Freeway Reference guide. All I see is Name, Value, Type (Text, Password, File Upload), Size and Access Key. Can anyone help me out? I’m specifically looking for the “Required” checkbox.
Here’s the form in question:
http://www.logicalmachines.com/client-registration.html
Thanks in advance!
John
Is your page set as HTML5 - if not then you wont get that option.
Thanks Dave—that did the trick. As I said, the form was made a while back before HTML5 was available. Changing the page to HTML5 made the options magically appear!
Cheers, John
What you really mean that it was created before FW had an HTML5 page setting option.
I believe that HTML 5 has been around for over 10 years.
