I am using Pro and beginning a site with a template named Merge. I want to adjust the header. I can adjust the pixel height to 138 and the result is a header that is too short. Then I adjust to 139 and it is way too tall. In Freeway it looks fine, but in preview using Safari is where the odd behavior shows. I have tried to do the math in the remaining objects so everything adds up, but there is something I can’t figure out. I am working on the master page.
I think it has been fixed, although I am not sure how. I purchsed Pro 6 and opened the site there and it works fine.
But I do have another problem. I have a CSS menu action wherein I have clored the links as white with a hover as yellow. The links do show up as white, but no hover color change. ???
It is important when adding link styles to a CSS Menu item that you start with no style/colour declaration on the original text.
So if you have any colour added already then remove it before adding your link styles/colours from within the action.
