I have an odd situation with a button and its map area.
If I draw a rectangular graphic image to use as a button, round the corners, add a 1 pixel border and then use it as a link to another page, everything is as it should be.
If, without changing anything else, I add an outer glow to the graphic and republish, the map area is offset to the button - see the link example.
Am I doing something wrong and is there a workaround?
This looks like a bug. Can you send the Freeway file to support(a)softpress.com, please?
On 23 Feb 2013, at 19:19, Andrew Barton email@hidden wrote:
Hi,
