[Pro] old xxxy.fwgallery
Hi,
There is an old old xxxy.fwgallery file which I cannot open with FRW 6.1
It is listed as Missing in the FRW Resources,
(after a change of media folders bec. Clean Install) what to I do with it?
PS: The gallery as such is still working.
with best regards,
Omar K N
Stockholm, Sweden
If I recall correctly, a fwgallery file is the output of Showcase.app, not Freeway, and isn’t an “openable” file at all. It’s a package of resources that the Showcase Action uses to build an on-screen representation of the slide show you created in Showcase.
On Apr 20, 2014, at 4:58 AM, OmarKN wrote:
Hi,
with best regards,
Omar K N
Stockholm, Sweden
Yes that is correct.
The actual Showcase file has the ‘kind’ of SPGalleryDocument so do a search for that if you want to find the original file and edit/re-export.
