I have a bunch of folders for all the websites I’ve created with Freeway sitting in my “documents” folder. I want to gather all those folders and put it into a folder named “websites”. If I do this, will it mess up my files when I want to open it and make revisions?
I kind of remember Dreamweaver saying that folders should only be moved from within the application. Is Freeway the same way?
Your expert guidance would be greatly appreciated.
I believe that Freeway reorganizes itself if folders get moved as long as you don’t move things all over the place. I know when I do a Save To Archive that even if I move the site folder from my desktop to an archiving folder it still remembers where I put it. It’s always best to test it out, create a Freeway document, attach an image to the page, publish it, and then move the folder around and see if it sticks.
Freeway works in a document format, like Quark. So it saves your entire web document to a .freeway file instead of just published HTML pages. The HTML files are located in a user created site folder and have no effect on your actual Freeway file working or not.
