Try changing the style from #PageDiv to body, see if that does the trick.
Would that be like this?
#body
I think this is it:
tag: body
extended:
name: overflow-y value: scroll
name: overflow-x value: hidden
Nope. That didn’t validate.
Errors:
/css/sheet1.css
12 body Property overflow-y doesn’t exist in CSS level 2.1 but exists in : scroll scroll
/index.html
17 body Property overflow-y doesn’t exist in CSS level 2.1 but exists in : scroll scroll
It didn’t validate when I took out the “overflow-x, value: hidden” either.
Try this, which works in a hand-coded test page.
html, body {
width: 100%;
height: 100%;
padding: 0;
margin: 0;
#PageDiv {
height: 100%;
overflow-y: scroll;
On Sep 18, 2010, at 12:47 AM, rebeccintosh wrote:
I think this is it:
tag: body
extended:
Hi Walter,
Would I put this code into Page: html markup:
Before /head, inside a style block.
… so it would be Before with the following code?
html, body { width: 100%; height: 100%; padding: 0; margin: 0; } #PageDiv { height: 100%; overflow-y: scroll; }freewaytalk mailing list
<style type="text/css">
styles here
</style>
In the Before (before end head) section.
Thank U!
Hi Walter,
Would you mind taking a look? I don’t know what I did incorrectly, but it won’t give me a CSS validation …
I clicked on the site folder, went to Page in the top menu, and inserted the code below in Before .
html, body { width: 100%; height: 100%; padding: 0; margin: 0; } #PageDiv { height: 100%; overflow-y: scroll; }Your old styles are still in there, probably left over from your
previous attempt to style the entire site folder using the Styles
palette. You’ll need to remove these, possibly by going through each
page and removing them in the Style Cascade section of the Inspector.
Next, your new styles are not present. You’ll need to select each of
the relevant Master Pages in the Site pane, then open Page / HTML
Markup on each one, paste into Before /HEAD, and move along to the
next one.
Spot-check to be sure that your styles have “taken” on the child pages
by clicking on a page or 8 at random, and checking in the Page / HTML
Markup dialog to be sure that the Master content is present.
As far as I know, selecting the Site Folder in the Site pane and
applying Page/HTML Markup from there doesn’t have any effect.
On Sep 20, 2010, at 4:15 PM, rebeccintosh wrote:
Hi Walter,
html, body { width: 100%; height: 100%; padding: 0; margin: 0; } #PageDiv { height: 100%; overflow-y: scroll; } </style _______________________________________________ freewaytalk mailing list email@hidden Update your subscriptions at: http://freewaytalk.net/person/options
It still won’t give me an W3 CSS validation. Here’s the link to the errors they report:
The first line of your stylesheet includes this:
body { overflow-y:scroll; overflow-x:hidden; margin:0px; background-
color:#fff; height:100% }
That’s what you have to get rid of. I am not sure how you added this,
perhaps it is in your Styles palette, perhaps it’s somewhere else.
And I still don’t see the new styles defining the height of body and
html, and setting the overflow on PageDiv. Did you upload to your
server again, at the previous URL you posted?
errors they report:
Hi Walter,
I did have the previous css page style on (body), and now it validates, but the scroll bars are are the boders of the page, not the browser. Is there anything I can do there?
i.e., these scroll bars look good:
http://tinyurl.com/266o6rn
These don’t:
http://tinyurl.com/2adkx4d
I found this code online (dated Apr. 2010)
Would any of this help?
filename: styles.css
/* eliminate page shift /
html {
min-height: 100%;
margin-bottom: 1px;
/ For Firefox 3.5 or later */
overflow: -moz-scrollbars-vertical !important;
overflow-y: scroll;
filename: styles-ie.css
/* eliminate page shift */
html {
min-height: 100%;
margin-bottom: 1px;
overflow-y: scroll;
Don’t center the page in the Inspector. Then they will be where you
expect them to be. If you want to center the middle content in the
page, just use the inline page construction technique I outlined a few
days back. Look for a subject line like full-width footer or something
like that.
On Sep 22, 2010, at 7:15 PM, rebeccintosh wrote:
Hi Walter,
the browser. Is there anything I can do there?i.e., these scroll bars look good:
http://tinyurl.com/266o6rnThese don’t:
Would any of this help?filename: styles.css
html {
min-height: 100%;
margin-bottom: 1px;
overflow-y: scroll;
}filename: styles-ie.css
html {
min-height: 100%;
margin-bottom: 1px;
overflow-y: scroll;
