Sometime around 5/1/10 (at 18:36 -0500) Martyn Page said:
I have just been emailed a link and advised that standard meta tag
will work with IE, however they will not work on Safari
http://www.aim-higher.net/meta-transitions.asp
Hi again Martyn,
Thanks for the link. That’s one hell of a freaky site! On Firefox and
Safari for Mac and Firefox for Windows 7 the page looks like
something from 1996. Only Internet Explorer (IE8) rendered the page
‘properly’. Although properly is hardly the right term for something
so broken elsewhere.
I’ve looked at the rendered page, I’ve looked at the HTML, and I’ve
looked at the CSS, and it almost looks like something designed
specifically to work properly only in IE. Ironic, as part of the
CSS file contains explicitly documented hacks to get IE 6 to behave
right with certain instructions and notes that IE5 and Netscape
Navigator 4 won’t behave. I can think of only one thing to say about
that: WTF?
Anyway, back to the point. It looks like those transitions are not at
all hard to implement. There’s a one-liner META tag to add, a small
chunk of JavaScript, and you’ll be ready to go.
Do be aware that they will ONLY work in Internet Explorer. Because of
that, you really should think twice about implementing them except
where they are utterly unimportant. I’m all in favour of creative and
innovative web design, but it is important to try and make things
work cross-browser and cross-platform wherever possible. It really
isn’t that hard!
(I mean, it really isn’t hard to make a page that looks (a) good and
(b) consistent across browsers and platforms - AND include this
IE-only trick.)
Also please note that every transition other than the dissolve may
look rather unprofessional to most visitors, and the dissolve is a
1-bit pixel dither transition - it isn’t a cross-fading dissolve.
However, I know nothing of your site plans or imposed requirements.
I’ve copied out the necessary JavaScript. I haven’t tested it, but
implementing it in Freeway should take you about 15 seconds or less.
Let me know if you need pointers.
k
