[Pro] Page Load Options
http://markhaagmusic.com/portfolio.html
There is a lot of content on this page between the videos and music files. And there is more to come. What are my options for having it load cleaner? I tried to apply Protaculous and do a “Lazy Loader” as per the previous thread, but does that only work on images and not Vimeo embedded videos? It didn’t seem to do anything for my situation so I took it off. Do I have any other options? Thanks for the feedback.
JC
actionsdev mailing list
The lazy-loading setup I posted a while back could be extended to work
with something other than images, but it would be a fair bit of work.
Looking at your page, it seems like all of the video is posted in a
fairly quick-loading manner (there’s be no need to use a proxy for
those elements) but your audio is posted directly to the page. You
might want to look at using an MP3 player widget that uses JavaScript
or Flash to lazy-load the sound file only when it’s clicked on. There
are hundreds of those out there. I’ve used this one a lot: http://flash-mp3-player.net/
JC
