[Pro] Page shift
I am using freeway 5 pro v5.4.2. I designed my website and when i upload it to the server the page shifts. the layout in freeway is perfect. At the bottom you’ll see what i mean. Here is the link to the page http://csdesignmtl.com/pricing.html# is there a way to resolve this problem. For each page i am using a different background. Should i use a steady size and add scroll bars on the rest. I will really appreciate it, thank you in advance.
Not quite sure what I should be seeing on your linked page. Can you be more specific.
BTW the most recent version of FW 5.4 is 5.4.3 so you should update to at least that version.
The line that says, All photographs on this website are copyrighted.© 2011 CSDesignMtl rights reserved. Website Designed by CSDesignMtl should be in the middle of the gold. Not below the gold.
But you didn’t put the text within the Gold box did you?
You may have drawn the text box on top of the gold one but that will not keep things together when your page is viewed at slightly different text sizes. As different browsers/OS tend to do.
To simulate how other viewers will see your page - at varying font sizes - in Safaris View Menu go down and Tick ‘Zoom Text Only’ now when looking at your page use Cmd+ to increase the text size by a couple of notches.
See how everything on your page starts to overlap?
The cure for this in earlier versions of FW (before the RPL action was introduced) was to make your page an inline layout - sometimes referred to as the Box Model.
