[Pro] partly scroll and partly fixed
How can I make a page where a part of the page is fixed (f.i. the top half with links and general information) and another part which has a scroll bar (f.i. the bottom half with pictures). So that when you scroll through the pictures the top part stays.
Thank you very much for helping.
You can do this a couple of ways.
1 Involves Fixed in Window - a setting in the Inspector where you can set an objects position to be Fixed in the Window ie have a relative distance from the top of the viewers window no matter what part of the page they are looking at. example: http://deltadzine.net/test/partscroll.html
2 Using an iFrame - create your normal page (ie page.html) with navigation etc and then underneath that Insert>Action Item>iFrame - size it according to the content that you want to show.
Create a new page in FW (ie pictures.html) with your picture layout etc and nothing else
Go back to the page with the iFrame and in the action inspector URL - choose the picture page you created. Scrolling:Auto and frame, border settings etc if you want them. Give it a name and you are done. Preview page.html and see if it what you want. Example: http://deltadzine.net/test/scroll2.html
There are other methods but this will get you started.
Thanks David, this will for sure get me started.
Raymond
