[Pro] Pass-through SVG causes scroll bars
I have been importing SVGs as pass-through graphics in order to have resolution independent graphics on retina displays, and they look great on my iPad.
The issue I have is that when I “Fit Box to Content,” I get scroll bars on the webpage around the graphic (in Safari and Chrome on my Mac), and the image is clipped on my iPad.
I found that making the HTML item 16 pixels wider and taller than the image I import eliminates the scroll bars. Is there a way around this? I would like the containing HTML item to be no bigger than the graphic itself.
I referred to the following KnowledgeBase article for pass-through SVGs:
Thanks!
I have loaded an SVG graphic (html item, pass through) which previews locally in all browsers but when uploaded displays only the code.
Any idea what I’m doing wrong?
Can you post a link to it online.
I gave up on placing the image and instead placed the code from Adobe Illustrator into an html frame. I used the action source code snooper to tweak the position.
Here’s the link.
I think you may have needed to set the SVG MIME type on your server. This can be done in various ways, the most common is through a .htaccess file, though this depends on your server and web-host.
http://www.w3.org/TR/SVG/intro.html#MIMEType
Here’s the link.
Www.brucedaly.com
