Is there an action that will only pause the sequence timer?
If this does not exist could anyone explain how to edit the existing Play/Pause Sequence Timer Action to only do the Pause function?
We would like to make a slide show that has a graphic dot that represents each page. When the user clicks any of the dots for the first time the sequence timer stops. They can then click any other dot to navigate to it’s corresponding slide and it would reveal the slide but not start the timer once again.
Thank you so much. . . this seems to do the trick. Just out of curiosity, are there values that could be entered in the parentheses that would provide other functionality?
