Joe_Shep
(Joe Shep)
March 28, 2016, 12:15pm
1
Hi there
I’ve been trying to add a paypal button to a webpage, but whenever it is clicked it just goes to a search results page instead of the paypal page.
From reading some of the other threads, it seems like there is a problem using paypal buttons when there are other forms on the page. However, I’ve also read a thread that seemed to suggest that the simple site search action should work fine with the paypal button.
The example is here: KwikFixSkills | Support KwikFixSkills
Any help is much appreciated. Also, apologies in advance but I have extremely minimal knowledge of writing code etc!
The purpose of this topic is to provide information about the migration from FreewayTalk and Groups io to Discourse and the differences in Discourse, as well as a place to discuss the good or bad of the migration. For those previously subscribing...
Reading time: 2 mins 🕑
Likes: 1 ❤
You actually have 3 forms on that page.
Simple Site, The email sign up and the PayPal button.
Remove the others in turn until your PP button works - the easiest solution for you would be to have just the PP Button on that page.
Likes: 1 ❤
Joe_Shep
(Joe Shep)
April 4, 2016, 1:42pm
3
Thanks Dave.
I presume there’s no way of getting it to work if the other forms stay on the page?
Likes: 1 ❤
You can try the Multiple Form/No Form actions - a mixture of which might work for you.
You dont really need Simple Site Search on every page - in cases like this I will quite often put a link to a dedicated Search Page.
You can also wrap a form in an iFrame ie (your email sign up) could be on its own page but referenced in an iFrame on the Support page.
Lots of things to try.
Likes: 1 ❤
