I am wanting a photo to go from side to side in the browser window like this example site. Does anyone know how I can do this in Freeway? Actually I’m wanting to do this with a carousal 2. Thanks for your help in advance.
How about something like this that is is only a graphic and does not carousal. just a static graphic like this site has but is only a graphic and does not move.
That’s a carousel, albeit one that does not animate. It uses the same basic construction as any carousel effect. The Carousel Action complains if you set its animation duration down that low, but you would get this effect by setting the duration to 0. You could also do this using nothing but CSS. because an anchor link will “pull” a nested div within an overflow:hidden parent into view.
Sounds to me you’re talking about a full with image.
Yes, a full width image from side to side, without any carousal or slide show. Basically only an image. I was using this site for an example for the graphic width, not the slider.
