Typing the following URL into the browser address bar…
http://hartford.macusa.net/fmi/iwp/cgi?-db=Install_Info.fp7&-startsession
…displays Login page:
http://hartford.macusa.net/fmi/iwp/res/iwp_auth.html
Examining imp_auth.html in Safari’s Console reveals the following JavaScript:
<script type="text/javascript" language="JavaScript1.4">
function setCookie(cookieName,value)
var today=new Date();
today.setDate(today.getDate()+ 1);
document.cookie=cookieName+ "=" +escape(value)+ ";expires="+today;
function getCookie(name)
var start = document.cookie.indexOf( name + "=" );
if (start == -1) return null;
var nameLength = start + name.length + 1;
var end = document.cookie.indexOf( ';', nameLength );
if (end == -1) end = document.cookie.length;
return unescape(document.cookie.substring( nameLength, end ));
function checkCookie(){
setCookie('check','check');
testCookie = getCookie('check');
if(testCookie == null){
return false;
}else{
document.cookie = 'check' + '=' +';expires=Thu, 01-Jan-1970 00:00:01 GMT';
return true;
function getSid()
var url = window.top.location.href;
var result = "";
if ( url != null )
var sid = null;
var index = null;
if(checkCookie() == true){
index = url.indexOf( "JSESSIONID=" );
}else{
index = url.indexOf( ";jsessionid=" );
if ( index != -1 )
var end = url.indexOf ( "&", index );
if ( end != -1 )
result = url.substring ( index, end );
else
result = url.substr ( index );
return result;
var sid = getSid();
if ( sid.length > 0 ){
document.write ( '<script type="text/javascript" language="JavaScript1.4" src="/fmi/iwp/cgi' + sid+ '?-authinfo' + '"><' + '/script>' );
}else{
document.write ( '<script type="text/javascript" language="JavaScript1.4" src="/fmi/iwp/cgi?-authinfo' + '"><' + '/script>' );
</script>
<script type="text/javascript" language="JavaScript1.4" src="/fmi/iwp/cgi?-getstrings"></script>
function disableFields()
var acct = document.getElementById( "accnt" );
var pass = document.getElementById( "pass" );
acct.disabled = true;
pass.disabled = true;
function enableFields()
acct.disabled = false;
pass.disabled = false;
function setup()
var ai = window.authinfo;
var name = document.getElementById( "thingy" );
var guest = document.getElementById( "guest-radio" );
var account = document.getElementById( "acct-radio" );
var login = document.getElementById( "login" );
var cancel = document.getElementById( "cancel" );
login.setAttribute( "value", iwp.strings.auth_btn_login );
cancel.setAttribute( "value", iwp.strings.stat_btn_cancel );
document.title = iwp.strings.home_ttl_iwp;
if ( ai != null && name != null )
var txt;
var sid = getSid();
var form = document.getElementById( "form-elt" );
if ( ai.realm.substring( 0, 9 ) == "FileMaker" )
txt = document.createTextNode( iwp.strings.auth_lbl_openfms );
var type = document.getElementById( "type" );
form.action = "/fmi/iwp/cgi" +sid+ "?-authserver";
else
form.action = "/fmi/iwp/cgi?-authserver";
type.name = "-authserver";
cancel.style.visibility = "hidden";
else
form.action = "/fmi/iwp/cgi" + sid + "?-authdb";
txt = document.createTextNode( iwp.strings.auth_lbl_opendb + ai.realm.substring( 9 ) + iwp.strings.auth_lbl_with );
name.appendChild( txt );
if ( ai.guest == "no" )
account.checked = true;
guest.disabled = true;
if ( ai.retrycount > 0 )
if ( ai.retrycount >= 4 && ai.dbpath != null )
window.location = "/fmi/iwp/cgi?-home&reset";
var msg = document.getElementById( "msg" );
msg.removeChild( msg.lastChild );
var txt;
txt = document.createTextNode( iwp.strings.auth_err_server );
else
txt = document.createTextNode( iwp.strings.auth_err_incorrect );
msg.appendChild( txt );
if ( ai.dbpath != null )
var hidden = document.getElementById( "dbpath" );
hidden.value = ai.dbpath;
document.getElementById( "accnt" ).focus();
var obj = document.getElementById( "iwpTopBox" );
var txt = document.createTextNode( iwp.strings.home_ttl_banner );
obj.appendChild( txt );
if ( window.authinfo == null )
window.location = "/fmi/iwp/cgi?-home";
</script>
<link href="/fmi/iwp/res/iwp_home.css" rel="stylesheet" type="text/css">
</head>
<body onload="setup()">
This would seem to indicate that I cannot achieve my aims in PHP alone. Would you agree?
dynamo mailing list
