I have successfully uploaded my site but can’t get the php feedback form to work. It always comes up with an error.
I think I have been careful to follow all the instruction (including previous thread discussion) but with no success. suggestions?
site is www.unmistakablymarilyn.co.uk
I did notice that when I uploaded- the php form came up first cause it was called index.html (presumably the server thought it to be homepage) This was the default seeing the action made. I had to change the name of the file so that the homepage was the index.html
Hi Graham,
Are you using an IIS (Windows) server by any chance? Which web host are you using? I can see that PHP is running and it looks like the script is having problems getting the server to cooperate.
Can you clarify what was the default setting issue is please? The Action can’t select your error or success pages automatically.
