How to - mouse over pic - pic enlarges with text underneath. I tried the rollover and the show hide layer together, i may need more facts on what to select to make it work, any advise or links to read!
This page is an example of an alternate way of creating Rollovers but uses Target Show/Hide Layer to display the Text box below (and can show an image at the same time). I have added a graphic showing the settings on the Target Show/Hide Layer which are duplicated for the picture box.
Hi Dave,
thanks this is exactly what i want, the rollover with the show hide layer.
Question: do I make the rollover image the pic in large size with the words under it as a jpg (or other type?), and load it in as the C.png image complete.
I don’t understand the images, so first I import one small 90px x 80px then I apply to it a rollover - In 2 columns- Normal has a tick and mouseover an image name?
Parameters:
Mouseover - image same one as I have imported into the thumbnail.
Click: none
Restore: yes
Preload: yes
find targets: top
Target Group: indigo
Mouseover: #1 (not sure how this connects?)
Click#: No
Then I imported a large image of the same thumbnail 200px x 220px, I added action of the Target show hide layer.
Initially: Hidden
Restore: yes
Effect: fade
Duration: 0.5
Target Group: Indigo
Target #1 ? (not sure how this works?)
So then I put the small image over the large, please can you clarify for me. Thanks for your patience
A rollover might not be the best fit for this construction. Try using the Target Show/Hide layer. Draw an HTML box, and double click inside it. Place your large photo within it as an inline image, and then type your text that you want to appear below the photo. Give the HTML box a white (or other solid color) background, and maybe some padding so it doesn’t look odd when it appears over the top of other content. Now apply the Target Show/Hide Layer Action to that HTML box and set it to a trigger number and color, and initially hidden.
Next, apply the Rollover Action to the element you want to trigger the large photo + text to appear. Set the mouseover number and color to match the target. In this usage, there is no need to have a second photo in the Rollover stack. When you mouse over this element, the larger HTML box will appear. Depending on the settings in Rollover, it will either stay visible, or disappear the moment you mouse out of the trigger element.
On Feb 13, 2012, at 11:36 PM, Andrina wrote:
Also I have a box of text I would like to come up under the image and can not work out how to do it.
