Simple. Upload your hi-res images to a separate location. In Exhibeo, open
your Thumbly gallery. Click the little grid of squares at the window bottom
to access the caption editing feature. Double click each image and manually
add a hyperlink to the hi-res version.
###Manually adding hyperlinks
If you’re not experienced at manually adding hyperlinks, DON’T PANIC… it’s
not rocket surgery.
There are basically 2 flavors of hyperlink - ABSOLUTE and RELATIVE.
Absolute links are those ones that start with the http://
bit like http://www.mysite.com/hires-images/image123.jpeg
. Absolute links tell the
browser exactly where to look for the object of the link
Relative links on the other hand, tell the browser where to find the link
object in relation to the link itself. This makes it easy to test your web
document on your local machine or on your server, and is how Freeway
commonly structures it’s internal links – as in
or ../hires-images/image123.jpeg
. However,
if you manually write a relative link but get the relative location wrong
(which is easy to do) then the browser sees it as broken or not found.
Now, there are plenty of different ways to do this, I think the simplest is
to create an empty subfolder in your Freeway file called hires-images
After you publish and upload your website, use and FTP app to upload the
hi-res images into it.
But BEFORE doing that, make your Thumbly gallery and anticipate the links
and add those ahead of time.
If you don’t have some already complicated, nested folder structure for
your website, then the link formula will be straight-forward. For example:
would be the absolute way to say (1) the server location, (2) the
sub-folder location, (3) the filename. You would have to know each of the
hi-res image file names (those names should fit internet naming
conventions… alphanumeric, no spaces, etc.). The same holds true for
relative links:
which indicates the location (1) from the top web directory (2) sub-folder,
(3) filename. In either case, spelling must be exact - typos are not
tolerated. Which sounds all serious (it is) but it’s not impossible either
as long as you follow these rules. Do it a few times and you’ll see how
possible all the impossible stuff truly is.
Exhibeo mailing list
