Why is the bottom picture shifting? It is the same size and everything as the other images
http://www.howardspaethportfolio.com/websitedesign.html
Todd1
(Todd)
September 19, 2014, 12:25am
2
If you use the browser’s (Safari, FF, Chrome etc.) Web Inspector tool you’ll see that section has a different html/div structure compared to the others, as though you didn’t insert the divs inside each other in the same way as the other sections. Get that sorted and it’ll work.
Better yet see if you can use fewer divs, there are a lot in there which might be part of the reason the page loads so slowly for me.
How can i delete all the div tags?
The wrapper didnt copy, so i fixed that, it loads slow for you? It doesnt for me on any browser…hmmm
Todd1
(Todd)
September 19, 2014, 12:36am
5
You should rethink how you structure those sections. Ask yourself if each div is necessary to achieve the desired result.
As for the load time, it may just be my connection but other sites load very quickly so who knows. Do a speed test at GTMetrix http://gtmetrix.com .
Well, I want it to be separated but I could put those slideshows in the middle of one
Todd1
(Todd)
September 19, 2014, 12:41am
7
My point is that it’s worth getting into the habit of thinking semantically. A div is the code equivalent of Switzerland, it’s semantically neutral.
Yeah, I just moved the slideshow into one wrapper
