I’m a newbie to Freeway Pro and just finding my feet.
I’ve created a simple rollover with a button I’ve created in Illustrator. The the two rollover states are saved as PNG-24’s, one is green, the other grey (the rollover state).
When I create the rollover large, the two states seamlessly flash between each other. Great. But when I reduce the rollover down in size and preview it, it starts to looks pixelated and I can see a whisp of grey around the edge of the green.
Ever the perfectionist I’m hoping someone can tell me what I’m doing wrong.
When you scale it down, are you sure that it is still set to PNG-24? Are you scaling in Freeway or Photoshop?
On Apr 26, 2012, at 3:12 AM, Mark Lawrence wrote:
Hi everyone.
Thanks for reply. I’m scaling it down in freeway. I’m importing them slighter larger than I need them as it seems to give me a better resolution.
When I import them large and preview it, the rollover looks seamless, then when I reduce it in size (to it’s finished size) when I preview it again, the smaller version doesn’t look sharp at all.
Firstly, I’d like to thank you for your time. Secondly I’d like to report that I worked it out! By creating the graphics at exactly the size I needed them (not scaling them down) they work beautifully.
