I have place drop shadow on several rectangular and square images in my site. I have several images with irregular shapes upon which I want to place a drop shadow. How can I accomplish this in Freeway?
If you use the Graphic>Path tool to draw your irregular shape then you can apply a shadow in the Graphic Item Inspector down in the Effects section under the paintbrush tab.
I’m beginning to feel illiterate as I’m not being really clear. but I’m trying to accurately outline an object in a photo, land then apply a drop shadow to that outlined object. I think I can only do that in Photoshop.
If you import one copy of the photo into a regular square box, and a second copy into an irregular (drawn in Freeway) box, and position them exactly one above the other, you can do this all within Freeway. If you set those two images to merge on output, the effect will be complete.
On Nov 18, 2011, at 8:51 PM, Joe wrote:
Thanks Dave,
