[Pro] Placing adsense on my web
Hi I have freeway Pro 5 and am a beginner building my first web. I have an adsense code and want the adverts to go into a specified place on the web page. Have clicked on the actions adsense in the menu and placed where I want it on the page. Where do I copy the code from google to please? Many thanks
Go to the Insert Menu then select “Mark Up Item”.
You won’t be able to see the ad sense content until you preview or publish the site.
Also meant to say to paste your code into the box that appears after you select Mark Up Item.
Hi Rich You are a star! Many thanks it worked Elizabeth
I had the same question but I found this thread by using Search. However, I think it needs clarification.
The “code” that you paste in is not the full Javascript provided by Google. All you need paste in is your personal “Ad Client” code, which looks like pub-1234567890123456
If you can not see the window where you must paste this code, select the “Google Adsense” box then go Window → Actions to open it.
You can place more than one Assense box on a page (for example horizontal and vertical).
