I’m trying to produce some backgrounds in Illustrator as a 10px sq for tiling in FWP, they look fine until previewed or published which produces poor quality results. I’m importing them as .ai files and I’ve tried PNG’s, but PNG files which look better, produce a vertical white line between every vertically tiled column. What am I doing wrong?
Actually, no it doesn’t, but there is antialiasing which may be causing the white (or light grey) line. But I’m more interested as to why an imported .ai file of 10px square set as a tiled background image does not publish very well.
Your best bet is to make the tiling image a web-graphic first and then import it. That way Freeway doesn’t have to guess what format you want the image to be when it’s output.
I agree. If you have Photoshop, just copy the item(s) in Illustrator,
switch to Photoshop and paste into your document. Choose Paste as Smart
Object and you will be able to resize, reposition, and otherwise style the
vector group. Then use Save for Web to fine-tune your web graphic.
