Just created a Showcase Gallery, and it works great. But the large image quality is really poor when i preview in a browser. Lots of pixelation. Its as if the large image was generated from a blown-up thumbnail image.
Source images are JPEG, 1936 x 2592, and look fine when opened in any other software, even a Browser or Preview.
Not sure if this helps, but you can change the resolution of the larger images in the panel. Alternatively try resizing your source images in PS to a size closer to what you want, then import them again.
Nathan and David-
The pass-through works great. I’ll probably resize each image to what i like for the big photo and then use the pass-through.
Thank you both very much.
James
