hey,
I would like to recreate the pop-out menu in freeway like in this site:
http://www.dtelepathy.com/
anybody got any thoughts/tips/trics?
hey,
Yup - walk before you try and run!
You can get the panel to pop down (not sideways) using the FX Transition Action. But you’ll probably end up writing a custom JavaScript effect using the Scriptaculous 2 Action, Scriptaculous Effects, and a bunch of hand-code (or jQuery and a bunch of hand-code). There isn’t anything in Freeway that can make this effect for you without code.
On Oct 16, 2015, at 8:23 AM, Yannick email@hidden wrote:
hey,
http://www.dtelepathy.com/anybody got any thoughts/tips/trics?
Thanks Walter!
The FX Transition is a good idea and an easy fix.
But it isnt 100% what i want, so I started coding…
Thumbs up since its my first try at this
Yannick
