It won’t let me link anything to a button, that’s the problem I am having.
It has the red dots around it and I can not link anything to the button
Don’t use a button - use a graphic or text
Looks like i will have to have it say " cancel" and “close” in text. No big deal I guess
Take a screenshot of your cancel button and use that
That is not a bad option actually
Draw a regular form button, click once on it and choose Item / Extended. In the tab, add the following name/value pair:
onclick
top.document,getElementById('_closer').click()
That should do the same thing as the link.
Willl try it and let you know what happens. Now trying to get the form to fit on mobile devices
Walt. that worked perfectly! Now trying to resize for mobile devices!
Take all border spacing etc off your table and that will shave a lump off its width.
Yeah, I got it fixed and i centered the text and it looks awesome now.
i followed this thread, can you show us an example of the result?
Op 25 nov. 2014 00:02 schreef “Howard Spaeth” email@hidden:
Sure can. Just go to www.hgrantdesigns.com/zieglar and click on the Phone icon under " have us call you"
That is what this whole thread was about
grazi!
2014-11-25 0:16 GMT+01:00 Howard Spaeth email@hidden:
icon under " have us call you"That is what this whole thread was about
I have to disagree - it looks like it was made in the late 80’s
http://www.hgrantdesigns.com/zieglar/callform.html
It would look a lot more modern if you got rid of the borders and aligned the text to the input fields.
You can probably vertical-align the table cells and get rid of all the
borders and it would look less last-century.
They are aligned to the text fields… I am confused on what you mean by that
I think I fixed it. Let me know how it looks now
Much improved but I would align left the input fields so that you have a straight LH edge.
Will try it and see how it looks with scripty
