[Pro] Pop up warning when link is clicked
Hi All,
One of our clients has asked for a pop up alert to come up when an external link is clicked. This is for some regulatory thing to say 'You are now leaving the site of…"
Anyone know how to do this?
The said link is the ‘Latest News’ HTML markup on the bottom right.
Graeme
Of what?
Apply Protaculous to the page. Choose prototype-packed from the Function picker. Click on the top Function Body button and paste in the following:
var here = window.location.hostname;
$$('a[href]').reject(function(elm){
	return (elm.href.hostname == here);
}).invoke('observe', 'click', function(evt){
	evt.stop();
	var msg = 'You are about to leave this site.' +
	"nn" +
	'Are you sure you want to do that?';
	if(confirm(msg)){
		window.location.href = elm.href;
That should kink every outbound link on the page to display the confirmation dialog.
On Oct 29, 2012, at 10:40 AM, Graeme wrote:
Hi All,
Graeme
Hi Walter
It seems to give the error on every link whether outbound or not.
Are you testing on your Mac or on the server? (I haven’t tried it in either place, wrote it off the top of my head.)
On Oct 29, 2012, at 8:29 PM, DeltaDave wrote:
Hi Walter
I can’t see why it’s acting this way. I guess the .hostname helper in JavaScript isn’t doing what I expect it to.
Hi Walter
Server
Hi All,
Sorry, the link is http://www.taylorcarmichael.co.uk/
Would the protaculous option be the best solution?
Graeme
Not until I figure out what went wrong with it. Dave pointed out (correctly) that it doesn’t work yet. window.location.hostname is not working the way I thought it would. The basic premise is there, I just need to figure out what to do for the test that decides if a link is local or not.
On Oct 30, 2012, at 6:08 AM, Graeme wrote:
Hi All,
Graeme
What about a slightly different approach. I found this bit of jQuery
window.onbeforeunload = function() {
    return "You're leaving the site.";
$(document).ready(function() {
    $('a[rel!=ext]').click(function() { window.onbeforeunload = null; });
Not quite sure how to translate that into script/protaculous but it does require the rel=“ext” to be added via Item Extended on external links.
Onbeforeunload fires before every page change. Same issue.
Okay, this works, tested locally and on server:
var here = window.location.protocol + '//' +
  return (elm.href.include(here));
  evt.stop();
  "nn" +
  if(confirm(msg)){
    window.location.href = this.href;
Sure - but using the qualifier should prevent that.
Moot anyway as your latest version does the job and is easier to implement.
Another solution for the war chest.
Thanks Walter
Sure, if you want to go through and add a rel attribute in Freeway to each external link, that’s another way to do it. In Prototype, it would be this simple:
$$('a[rel*="ext"]').invoke('observe','click', function(evt){
	evt.stop();
	if(confirm('your message'))
But then you have to hunt down the links you want to exhibit this behavior and mark them up with a rel attribute.
Thanks Walter
All useful info - I am sure I will find a use for it at some point.
Here’s one I wrote earlier that should trap all external links (links to _blank targets or absolute links) and pop a confirmation in front of the user before they go any further. Annoying, functional and lightweight.
http://www.freewayactions.com/code/?f=Confirm+Outbound+Links.txt
FreewayStyle.com - Free Freeway templates and parts to download, use and explore - http://www.freewaystyle.com
All looks good.
How do you implement your code Tim?
Graeme
Hi Graeme,
Copy the code on that page and paste it into your Freeway page/master page using Page > HTML Markup > Before .
Experienced Freeway designer for hire - http://www.freewayactions.com
