Hi all…
Is it possible to change the size of the font wbe n someome types in a form field? I know how to change the size of box but the actual text?
At this site…
The Form Element Styler Action can do this for you.
On Mar 13, 2013, at 5:53 PM, Barry Hoffman wrote:
Hi all…
At this site…
Just set the font size. The box will follow automatically. You can do a lot of things with this Action, and I recommend you use a very light hand. Only change a few things. It is very easy to make a form input that doesn’t look usable – people will ignore/be confused/both.
On Mar 13, 2013, at 6:02 PM, Barry Hoffman wrote:
Thanks. That must be what i use to make box bigger. Will checkat home
