Can Powerpoint pages be uploaded into Freeway pages
You can export PowerPoint into images or HTML from within that application. Once you do, you can upload the pages and link to them or import the images into your Freeway document.
Could the same be done with the MAC application called “keynote”.
import the images into your Freeway document.Walter
Yes, in even more formats.
(Also, point of grammar: MAC is an acronym for Media Access Control or Money Access Center, depending on whether it’s found on the back of your network card or on a cashpoint on the east coast of the US. Mac is a registered trademark “nickname” for Macintosh, which is a mis-spelling of the Mackintosh apple variety.)
Thanks for the point about the Mac! That’s also pretty cool that I can do
that with Keynote. I just did a pretty simple website for a client, but had
done a Keynote a while back that he might like to link to.
Carol
the Mackintosh apple variety.)Walter
wrote:You can export PowerPoint into images or HTML from within that
Thanks for the info, but; Do you mean Export from pp to freeway, or import from freeway to the pp document?
Export from PP in HTML or as a single graphic per slide (looks more like the original slide, but gets blurry at larger sizes). These will be self-contained files, either one HTML page per slide, or one image, and they can be handled depending on their format. If images, then you can place them in Freeway as usual. If HTML, then you could upload the files using an FTP application (put them in a separate folder within your site root on your server) and then link to them from Freeway using an External URL. If you wan to frame them into a page, you might try the iframe Action for that.
