When I “PREVIEW IN BROWSER”, my page looks as it should but when I upload it, it doesn’t work. I’m trying to display 2 separate graphic elements for 1 thumbnail.
I tried emptying the cache and I’ve waited a week so it’s neither of those. I also made sure the ‘Find Target’ setting is set to “Top”. Here is an example of what I’m trying to do:
Are you using the exactly the same Action parameters on the picture as well as the graphic text ie Target show/hide layer. Initially: Hidden, Restore: Yes, Effect: None, Target group: Indigo, Target#: 1, then 2 for the next pair, 3 for the next pair etc. etc.
Hey David. Thanks for the suggestion. Yes I just checked. It’s weird that it works in the “Preview” mode and not actually on the web. Any other thoughts?
Then try duplicating the photo layer, delete the content, add in your graphic text, move it/resize it and see if that works. Move your existing graphic text layers out the way while you try this.
