Hi,
i would like to add the “Bandsintown” plugin to my website but can’t really figure out how to do it. (i’m pretty new to all this :))
It’s a javascript, so what is the best way to add this to my website? I tried it with a markup item but I guess that’s not the way to do it?
Thank you very much,
Christophe
The script:
The website
www.djchristophe.be
This code in Page>HTML Markup in the before section
<script type=text/javascript src="http://www.bandsintown.com/javascripts/bit_widget.js"></script>
And then this using Insert>Markup Item and paste it in
<script type=text/javascript>var widget = new BIT.Widget({"artist":"StereoClash","prefix":"fbjs"});widget.insert_events();</script>
And they are all Belgian dates. http://www.deltadesign.co/fw_examples/bandsintown.html
Thanx Dave, this helps a lot!
Kind regards,
Christophe
