[Pro] Problem drawing Showcase action item
I have created a showcase gallery and I am trying for the first time to place it in a page. I click the Freeway Action icon and draw a box but the only option I get is an “Add This”. I don’t see anything that indicates Showcase.
I do have Showcase open.
You dont need Showcase running while you do the action bit in FW as it has done its job already.
Use the Insert Menu: Insert>Action Item>Showcase - Gallery/Slideshow.
This will place a 100px square on your FW page. Resize it and move it to where you want your gallery to appear.
With it still selected then go into the Action Inspector, add your Parameters and select your Gallery using the Gallery File selector.
Job done - preview.
