Again a big and curious problem with the FLV-player:
I put a Flash-Movie on the website of a customer … the movie does not run. Although other Flash-movies on the same site run without any problem.
Please look - this is the site of my customer: http://aktiv-in-brandenburg.de/30.8.2010_eberswalde/film.html
For testing the problem I put the same movie on my own website … and the movie runs without any problem.
Please look - this is my website: http://www.komm-konzept.de/test.html
Does anybody have an idea - that would be great!!!
bruno
This is probably a bug in older versions of the Action. Essentially, the problem happens when you have the movie on a page in a subdirectory. I can’t remember the exact workaround right now (either moving the page to the root level, so not in a directory, or changing the Resources option to “In each folder”) but upgrading to Freeway 5.5 will definitely fix the problem.
Hope this helps,
bruno
Thank your for you help, Joe!! This older version of the FLV-player is really a crazy thing!
I put the film “upstairs” on another page, where another Flash-movie was already running … and the movie does not run, whilst the other movie runs like before …
So I think I have no choice and must upgrade to 5.5
Best regards!
bruno
