I’ve been driving myself mad trying to figure this out. For some reason the grass and dirt footer at the bottom of this have moved up and I have no idea why.
I suspect it has something to do with the form code, but I don’t know what. Any help with this is greatly appreciated.
http://rcb.idealynx.com/contact-form.php
Here is a clue: One of these things is not like the other…
http://cssway.thebigerns.com/workbench/du_jour/kelly/Kelly-goodBad.jpg
idea why.
Thanks Ernie. I see that the class is missing, but isn’t that something Freeway Pro is suppose to write?
maybe obvious question!
how do you now view the code? - previously it was just View>Source but no longer
cheers
In Safari it’s Command + Option + U
that didn’t seem to work - but found this:
Safari menu > Preferences > Advanced.
Check “Show Develop menu in menu bar”. Close Safari’s preferences.
Develop menu > Show Page Source
Not sure why safari got rid of the View>Source option.
Not that I want to start coding, but it’s nice to see what it looks like!
No, you still don’t see it. Look more closely…
In the GOOD example, there is a div id FOOTER-WRAPPER to hold those
elements. It’s part of the structure of that page and is inline after
CONTENT-WRAPPER. However, In the BAD page THERE IS NO FOOTER-WRAPPER… not
at all. The footer elements are in the left-column sub div of the
CONTENT-WRAPPER div.
The pages are structurally different – with missing elements and elements
in the wrong structures.
I understand what you’re saying, but I think the problem is with the Perch code I’m inserting. I think there’s a or something else missing, which means FWP code is getting intermingled with the Perch code. If I remove the Perch code, the page is fine.
Here’s the Perch code:
<perch:form id="contact" method="post" app="perch_forms">
<div>
<perch:content id="introtext" type="textarea" label="Form Intro Text" html="true" editor="redactor" />
<p class="rule"> </p>
<div class="details">
<p><span class="step">Step 1 of 2:</span> Provide Your Contact Information <span class="note">(All fields in step 1 are required)</span></p>
<div class="col">
<perch:label for="name">First Name:</perch:label>
<perch:input type="text" name="firstname" value="" id="firstname" maxlength="30" tabindex="1" class="field" />
<perch:error for="name" type="required">
<span class="error">Please add your first name.</span>
</perch:error>
<perch:label for="name">Last Name:</perch:label>
<perch:input type="text" name="lastname" value="" id="lastname" maxlength="30" tabindex="2" class="field" />
<span class="clear"></span>
<span class="error">Please add your last name.</span>
</perch:error>
</div>
<p> </p>
<div class="col">
<perch:label for="email">Email Address:</perch:label>
<perch:input type="text" name='email' value="" id="email" required="true" label="Email" maxlength="50" tabindex="3" class="field" chars="200" />
<perch:error for="email" type="required">
<span class="error">Please add your email address.</span>
</perch:error>
<perch:label for="email">Confirm Email Address:</perch:label>
<perch:input type="text" name='emailconfirm' value="" id="emailconfirm" required="true" label="Email" maxlength="50" tabindex="4" class="field" chars="200" />
<span class="error">Please confirm your email address.</span>
</perch:error>
</div>
<p> </p>
<div class="col">
<perch:label for="zip">ZIP Code:</perch:label>
<perch:input type="text" name='zip' value="" id="zip" required="true" placeholder="zipcode" label="Email" maxlength="10" tabindex="5" class="field" chars="200" /> *
<span class="error">Please enter your zip code.</span>
</perch:error>
<label>Country</label>
<select name="country" id="country" tabindex="6">
<option value=""></option>
<option value="AF" >Afghanistan</option>
<option value="AL" >Albania</option>
<option value="DZ" >Algeria</option>
<option value="AD" >Andorra</option>
<option value="AO" >Angola</option>
<option value="AI" >Anguilla</option>
<option value="AQ" >Antartica</option>
<option value="AG" >Antigua and Barbuda</option>
<option value="AR" >Argentina</option>
<option value="AM" >Armenia</option>
<option value="AW" >Aruba</option>
<option value="AU" >Australia</option>
<option value="AT" >Austria</option>
<option value="AZ" >Azerbaijan</option>
<option value="BS" >Bahamas</option>
<option value="BH" >Bahrain</option>
<option value="BD" >Bangladesh</option>
<option value="BB" >Barbados</option>
<option value="BY" >Belarus</option>
<option value="BE" >Belgium</option>
<option value="BZ" >Belize</option>
<option value="BJ" >Benin</option>
<option value="BM" >Bermuda</option>
<option value="BT" >Bhutan</option>
<option value="BO" >Bolivia</option>
<option value="BA" >Bosnia-Herzegovina</option>
<option value="BW" >Botswana</option>
<option value="BV" >Bouvet Island</option>
<option value="BR" >Brazil</option>
<option value="IO" >British Indian Ocean Territory</option>
<option value="VG" >British Virgin Islands</option>
<option value="BN" >Brunei Darussalam</option>
<option value="BG" >Bulgaria</option>
<option value="BF" >Burkina Faso</option>
<option value="BI" >Burundi</option>
<option value="KH" >Cambodia</option>
<option value="CM" >Cameroon</option>
<option value="CA" >Canada</option>
<option value="CV" >Cape Verde</option>
<option value="KY" >Cayman Islands</option>
<option value="CF" >Central African Republic</option>
<option value="TD" >Chad</option>
<option value="CL" >Chile</option>
<option value="CN" >China</option>
<option value="CX" >Christmas Island</option>
<option value="CC" >Cocos Islands</option>
<option value="CO" >Colombia</option>
<option value="KM" >Comoros</option>
<option value="CG" >Congo</option>
<option value="CK" >Cook Islands</option>
<option value="CR" >Costa Rica</option>
<option value="CI" >Cote D'Ivoire</option>
<option value="HR" >Croatia</option>
<option value="CU" >Cuba</option>
<option value="CY" >Cyprus</option>
<option value="CZ" >Czech Republic</option>
<option value="DK" >Denmark</option>
<option value="DJ" >Djibouti</option>
<option value="DM" >Dominica</option>
<option value="DO" >Dominican Republic</option>
<option value="TP" >East Timor</option>
<option value="EC" >Ecuador</option>
<option value="EG" >Egypt</option>
<option value="SV" >El Salvador</option>
<option value="GQ" >Equatorial Guinea</option>
<option value="EE" >Estonia</option>
<option value="ET" >Ethiopia</option>
<option value="FO" >Faeroe Islands</option>
<option value="FK" >Falkland Islands</option>
<option value="FM" >Fed. States of Micronesia</option>
<option value="FJ" >Fiji</option>
<option value="FI" >Finland</option>
<option value="FR" >France</option>
<option value="GF" >French Guiana</option>
<option value="PF" >French Polynesia</option>
<option value="TF" >French Southern Territories</option>
<option value="GA" >Gabon</option>
<option value="GM" >Gambia</option>
<option value="GE" >Georgia</option>
<option value="DE" >Germany</option>
<option value="GH" >Ghana</option>
<option value="GI" >Gibraltar</option>
<option value="GR" >Greece</option>
<option value="GL" >Greenland</option>
<option value="GD" >Grenada</option>
<option value="GP" >Guadeloupe</option>
<option value="GT" >Guatemala</option>
<option value="GG" >Guernsey</option>
<option value="GN" >Guinea</option>
<option value="GW" >Guinea-Bissau</option>
<option value="GY" >Guyana</option>
<option value="HT" >Haiti</option>
<option value="HM" >Heard and McDonald Islands</option>
<option value="HN" >Honduras</option>
<option value="HK" >Hong Kong</option>
<option value="HU" >Hungary</option>
<option value="IS" >Iceland</option>
<option value="IN" >India</option>
<option value="ID" >Indonesia</option>
<option value="IR" >Iran</option>
<option value="IQ" >Iraq</option>
<option value="IE" >Ireland</option>
<option value="IM" >Isle of Man</option>
<option value="IL" >Israel</option>
<option value="IT" >Italy</option>
<option value="JM" >Jamaica</option>
<option value="JP" >Japan</option>
<option value="JE" >Jersey</option>
<option value="JO" >Jordan</option>
<option value="KZ" >Kazakhstan</option>
<option value="KE" >Kenya</option>
<option value="KI" >Kiribati</option>
<option value="KW" >Kuwait</option>
<option value="KG" >Kyrgyzstan</option>
<option value="LA" >Laos</option>
<option value="LV" >Latvia</option>
<option value="LB" >Lebanon</option>
<option value="LS" >Lesotho</option>
<option value="LR" >Liberia</option>
<option value="LY" >Libyan Arab Jamahiriya</option>
<option value="LI" >Liechtenstein</option>
<option value="LT" >Lithuania</option>
<option value="LU" >Luxembourg</option>
<option value="MO" >Macau</option>
<option value="MG" >Madagascar</option>
<option value="MW" >Malawi</option>
<option value="MY" >Malaysia</option>
<option value="MV" >Maldives</option>
<option value="ML" >Mali</option>
<option value="MT" >Malta</option>
<option value="MH" >Marshall Islands</option>
<option value="MQ" >Martinique</option>
<option value="MR" >Mauritania</option>
<option value="MU" >Mauritius</option>
<option value="MX" >Mexico</option>
<option value="MD" >Moldova</option>
<option value="MC" >Monaco</option>
<option value="MN" >Mongolia</option>
<option value="MS" >Montserrat</option>
<option value="MA" >Morocco</option>
<option value="MZ" >Mozambique</option>
<option value="MM" >Myanmar</option>
<option value="NA" >Namibia</option>
<option value="NR" >Nauru</option>
<option value="NP" >Nepal</option>
<option value="AN" >Netherland Antilles</option>
<option value="NL" >Netherlands</option>
<option value="NC" >New Caledonia</option>
<option value="NZ" >New Zealand</option>
<option value="NI" >Nicaragua</option>
<option value="NE" >Niger</option>
<option value="NG" >Nigeria</option>
<option value="NU" >Niue</option>
<option value="NF" >Norfolk Island</option>
<option value="KR" >North Korea</option>
<option value="MP" >Northern Mariana Islands</option>
<option value="NO" >Norway</option>
<option value="OM" >Oman</option>
<option value="PK" >Pakistan</option>
<option value="PW" >Palau</option>
<option value="PA" >Panama</option>
<option value="PZ" >Panama Canal Zone</option>
<option value="PG" >Papua New Guinea</option>
<option value="PY" >Paraguay</option>
<option value="PE" >Peru</option>
<option value="PH" >Philippines</option>
<option value="PN" >Pitcairn</option>
<option value="PL" >Poland</option>
<option value="PT" >Portugal</option>
<option value="QA" >Qatar</option>
<option value="RE" >Reunion</option>
<option value="RO" >Romania</option>
<option value="RU" >Russian Federation</option>
<option value="RW" >Rwanda</option>
<option value="KN" >Saint Kitts and Nevis</option>
<option value="LC" >Saint Lucia</option>
<option value="WS" >Samoa</option>
<option value="SM" >San Marino</option>
<option value="ST" >Sao Tome and Principe</option>
<option value="SA" >Saudi Arabia</option>
<option value="SN" >Senegal</option>
<option value="SC" >Seychelles</option>
<option value="SL" >Sierra Leone</option>
<option value="SG" >Singapore</option>
<option value="SK" >Slovakia</option>
<option value="SI" >Slovenia</option>
<option value="SB" >Solomon Islands</option>
<option value="SO" >Somalia</option>
<option value="ZA" >South Africa</option>
<option value="KP" >South Korea</option>
<option value="ES" >Spain</option>
<option value="LK" >Sri Lanka</option>
<option value="SH" >St. Helena</option>
<option value="PM" >St. Pierre and Miquelon</option>
<option value="VC" >St. Vincent and the Grenadines</option>
<option value="SD" >Sudan</option>
<option value="SR" >Suriname</option>
<option value="SJ" >Svalbard and Jan Mayen Islands</option>
<option value="SZ" >Swaziland</option>
<option value="SE" >Sweden</option>
<option value="CH" >Switzerland</option>
<option value="SY" >Syrian Arab Republic</option>
<option value="TW" >Taiwan</option>
<option value="TJ" >Tajikistan</option>
<option value="TZ" >Tanzania</option>
<option value="TH" >Thailand</option>
<option value="TG" >Togo</option>
<option value="TK" >Tokelau</option>
<option value="TO" >Tonga</option>
<option value="TT" >Trinidad and Tobago</option>
<option value="TN" >Tunisia</option>
<option value="TR" >Turkey</option>
<option value="TM" >Turkmenistan</option>
<option value="TC" >Turks and Caicos Islands</option>
<option value="TV" >Tuvalu</option>
<option value="AE" >U.A.E.</option>
<option value="UM" >U.S. Minor Outlying Islands</option>
<option value="UG" >Uganda</option>
<option value="UA" >Ukraine</option>
<option value="GB" >United Kingdom</option>
<option value="US" selected>United States</option>
<option value="UY" >Uruguay</option>
<option value="UZ" >Uzbekistan</option>
<option value="VU" >Vanuatu</option>
<option value="VA" >Vatican City State</option>
<option value="VE" >Venezuela</option>
<option value="VN" >Vietnam</option>
<option value="WF" >Wallis and Futuna Islands</option>
<option value="EH" >Western Sahara</option>
<option value="YE" >Yemen</option>
<option value="YU" >Yugoslavia</option>
<option value="ZR" >Zaire</option>
<option value="ZM" >Zambia</option>
<option value="ZW" >Zimbabwe</option>
</select>
</div>
<p> </p>
<div class="col3">
<perch:label>How we can help you?</perch:label>
<textarea type="textarea" name="comments" id="message" label="Message" tabindex="7"></textarea>
</div>
<p> </p>
<div class="additional">
<p><span class="step">Step 2 of 2:</span> Provide Additional Information <span class="note">(optional)</span></p>
<div class="left">
<div class="col">
<perch:label>Street Address</perch:label>
<perch:input type="text" name="address" id="address" maxlength="50" class="field" />
<perch:label>City</perch:label>
<perch:input type="text" name="city" id="city" maxlength="50" class="field" />
<perch:label>State</perch:label>
<select name="state" id="state">
<optgroup label="United States">
<option value="AL">Alabama</option>
<option value="AK">Alaska</option>
<option value="AZ">Arizona</option>
<option value="AR">Arkansas</option>
<option value="CA">California</option>
<option value="CO">Colorado</option>
<option value="CT">Connecticut</option>
<option value="DE">Deleware</option>
<option value="DC">District of Columbia</option>
<option value="FL">Florida</option>
<option value="GA">Georgia</option>
<option value="HI">Hawaii</option>
<option value="ID">Idaho</option>
<option value="IL">Illinois</option>
<option value="IN">Indiana</option>
<option value="IA">Iowa</option>
<option value="KS">Kansas</option>
<option value="KY">Kentucky</option>
<option value="LA">Louisiana</option>
<option value="ME">Maine</option>
<option value="MD">Maryland</option>
<option value="MA">Massachusetts</option>
<option value="MI">Michigan</option>
<option value="MN">Minnesota</option>
<option value="MS">Mississippi</option>
<option value="MO">Missouri</option>
<option value="MT">Montana</option>
<option value="NE">Nebraska</option>
<option value="NV">Nevada</option>
<option value="NH">New Hampshire</option>
<option value="NJ">New Jersey</option>
<option value="NM">New Mexico</option>
<option value="NY">New York</option>
<option value="NC">North Carolina</option>
<option value="ND">North Dakota</option>
<option value="OH">Ohio</option>
<option value="OK">Oklahoma</option>
<option value="OR">Oregon</option>
<option value="PA">Pennsylvania</option>
<option value="RI">Rhode Island</option>
<option value="SC">South Carolina</option>
<option value="SD">South Dakota</option>
<option value="TN">Tennessee</option>
<option value="TX">Texas</option>
<option value="UT">Utah</option>
<option value="VT">Vermont</option>
<option value="VA">Virginia</option>
<option value="WA">Washington</option>
<option value="WV">West Virginia</option>
<option value="WI">Wisconsin</option>
<option value="WY">Wyoming</option>
</optgroup>
<optgroup label="Canada">
<option value="AB">Alberta</option>
<option value="BC">British Columbia</option>
<option value="MB">Manitoba</option>
<option value="NB">New Brunswick</option>
<option value="NF">Newfoundland</option>
<option value="NT">Northwest Territories</option>
<option value="NS">Nova Scotia</option>
<option value="NU">Nunavut</option>
<option value="ON">Ontario</option>
<option value="PE">Prince Edward Island</option>
<option value="QC">Quebec</option>
<option value="SK">Saskatchewan</option>
<option value="YT">Yukon</option>
</optgroup>
</select>
<p> </p>
<div class="col">
<perch:label>Phone</perch:label>
<perch:input type="text" name="phone" id="phone" maxlength="30" class="field" />
<span class="float">
<input type="radio" name="primaryphone" value="Home" checked="checked" /> Home
<input type="radio" name="primaryphone" value="Work" /> Work
<input type="radio" name="primaryphone" value="Mobile" /> Mobile
</span>
</div>
<p> </p>
</div>
<div class="right">
<div class="col1">
<perch:label>What brought you to our website?</perch:label>
<select name="marketing_heardabout" id="marketing_heardabout">
<option value="">Select One</option>
<option value="Community Event">Community Event</option>
<option value="Contractor">Contractor</option>
<option value="Friend or Relative">Friend or Relative</option>
<option value="Promotional Flyer">Promotional Flyer</option>
<option value="Lot Sign">Lot Sign</option>
<option value="Magazine">Magazine</option>
<option value="Newspaper Ad">Newspaper Ad</option>
<option value="News Story">News Story</option>
<option value="Radio Ad">Radio Ad</option>
<option value="Realtor">Realtor</option>
<option value="River City Email">River City Email</option>
<option value="River City Facebook Page">River City Facebook Page</option>
<option value="Television Ad">Television Ad</option>
<option value="Other">Other</option>
</select>
</div>
</div>
<p> </p>
<div>
<perch:input type="submit" value="Send" />
<perch:input type="reset" value="Reset" />
</div>
<perch:success>
<perch:content id="success" type="textarea" label="Success Text" html="true" editor="redactor" />
</perch:success>
</perch:form>
Todd1
(Todd)
May 14, 2013, 3:05pm
10
I didn’t look at your code but I think you’re probably right, that’s what it sounds like.
So, how do I find the rogue
Todd1
(Todd)
May 14, 2013, 4:55pm
12
It looks like you might be missing 4 closing tags.
Some editors have a ‘balance tag’ (or similar) function. If that’s not an option and your editor has a code folding feature you can collapse unnecessary lines which makes it so much easier to spot the missing closing tags. That’s how I came up with 4 missing tags (though I could be wrong).
Which editor do you recommend?
Todd1
(Todd)
May 14, 2013, 5:15pm
14
I use Coda but any decent programming editor should do, such as: Sublime Text, TextMate, Espresso, BBEdit, Chocolate …
Does Coda have the option you’re talking about?
Todd1
(Todd)
May 14, 2013, 5:31pm
16
Coda has code-folding and will automatically close tags as you type them. There might be a plugin that checks for balanced tags in a preexisting doc but I’m not sure. They all offer free trials so try 'em all.
Okay, I got that son-of-a-^%$@#. You were dead on Todd. The code was missing exactly (2) tags.
Now, help me with this. What code do I use to insert a line space within a
? How about outside of a
Also, please refresh my memory. If I create a
within the Perch template, how do I target or style that class from within FWP?
Caleb_G1
(Caleb G)
May 14, 2013, 7:18pm
18
Coda 2 does have the Emmet plugin , which will show you the closing tag of a tag you have selected, but unfortunately there is no automatic balancing here in Coda world.
Thanks Caleb.
Todd1
(Todd)
May 14, 2013, 7:43pm
20
Do you mean a line break or soft return within a run of text, for example or something else? If so,
<br />
Class styles always start with a period (.) e.g., .classStyle
ID styles start with a hash/pound (#) e.g., #idStyle
In FW, if it’s just a class then add the name (e.g., classStyle) in the Name field and FW will add the leading period (.) for you. If it’s an ID style then put name (e.g., #idStyle ) in the Tag field and make sure the Name field is empty.
