suddenly the images do not change in% and I imported graphics with pass-through, to remedy the problem I had to write on “extended” 100%! important … Why does it work on other projects, but this no ??
It looks like at the 768px breakpoint the photo #Building has a fixed width
(560px). I think this is what’s causing issues requiring !important to
override, you’ll have to change that (remove it).
Freeway 7 lets you set the image with a % amount, that’s how you should
apply sizing to your images.
I may fail the theme here, but is it all a question of positioning? I mean: Absolute positioned vs. relative which makes the difference regarding percentage?
