[Pro] Problem with page background...
Greeting, all. Since I can’t attach screenshots to a site that’s not yet live, I’ll have to try and describe this problem I’m having.
Imagine an image to be used as a background. It’s 800 pixels wide by 10 pixels high. The left and right 5 pixels in are colored, while the rest of the 790 pixels are just white. This image is meant to be tiled vertically, and centered. The result should appear that the webpage has a 5 pixel colored line down the left and the right sides of the page. In the inspector, the Horizontal box says “Center” and the Vertical box says “Tile”. “Background Scrolls” is unchecked.
The problem I’m having is that while the height of the page is only set to 800 pixels, the background image continues to scroll on to the bottom of the browser window down past the bottom of the page.
I’m not sure how to tell the background image to just tile until it hits the bottom of the page as defined by the “Page Height” box value in the inspector.
Does this make sense? It appears that this may have started happening with a recent Freeway update. This is the latest version of Pro, by the way.
Any help or insight would be appreciated. Thank you.
The background you have created is really a background to the browser window so what you are seeing is normal behaviour.
If you want a background that stays within your FW page then you will need to apply a background to a FW page size div.
This Knowledgebase article may help Making your page area different to your browser background - Freeway - Softpress Talk
