I want to use Tahoma font in persian language. in freeway, it displays arial, body, or some other font while I selected Tahoma, and Tahoma only appears in browser or preview. it’s a bit bigger than other fonts in size, so it causes some bugging when I’m designing a page, in freeway everything is ok but in preview, texts will go out of their place because of size difference. how can I make freeway show Tahoma when I’m designing?
hello? can anybody solve my problem? I can not see tahoma font in FW. it shows arial instead, but in browser its ok.
I’d check your font set in Freeway.
Go to Edit > Font Sets…
Double-click the Tahoma set and check it’s using Tahoma for the screen font.
Once you’re done, OK you way back out and all should work properly for you.
Hope that helps.
Heather
iFlickr http://www.flickr.com/photos/snaptophobic/
Blather and Bluster http://snaptophobic.posterous.com/
iTweet http://twitter.com/Snaptophobic/
¬_¬
I changed it from Tahoma Regular to Tahoma Normal nad works, but characters are separate from each other. (ی س پ ر)
*and
Joe2
(Joe)
September 12, 2011, 2:21pm
6
Hi Khashayar,
What version of Freeway are you using? There was an issue with Microsoft fonts in Freeway 5 that has since been rectified in Freeway 5.5. You could try downloading the TrueType font from Microsoft here to see if that works:
http://www.microsoft.com/typography/fonts/font.aspx?FMID=1131
I’m using freeway pro 5.5 that I just downloaded 2 weeks ago.
in that link, Tahoma is paid. should I purchase it?
Joe2
(Joe)
September 12, 2011, 2:46pm
8
No, don’t buy it. Go to the Edit menu an Freeway, select Fonts and see if there are any errors listed in there.
I did but none of them were for Tahoma. here it is:
Font Problems
September 12, 2011 7:19:55 PM
INTERNAL FONTS. The following fonts are for internal use only.
Font: “.Times LT MM” Style: “Regular” File: “Macintosh HD:System:Library:Fonts:TimesLTMM”.
Font: “LastResort” Style: “Regular” File: “Macintosh HD:System:Library:Fonts:LastResort.ttf”.
Font: “.Keyboard” Style: “Regular” File: “Macintosh HD:System:Library:Fonts:Keyboard.ttf”.
Font: “.Helvetica Neue Desk UI” Style: “Bold Italic” File: “Macintosh HD:System:Library:Fonts:HelveticaNeueDeskUI.ttc”.
Font: “.Helvetica Neue Desk UI” Style: “Italic” File: “Macintosh HD:System:Library:Fonts:HelveticaNeueDeskUI.ttc”.
Font: “.Helvetica Neue Desk UI” Style: “Bold” File: “Macintosh HD:System:Library:Fonts:HelveticaNeueDeskUI.ttc”.
Font: “.Helvetica Neue Desk UI” Style: “Regular” File: “Macintosh HD:System:Library:Fonts:HelveticaNeueDeskUI.ttc”.
Font: “.Helvetica LT MM” Style: “Regular” File: “Macintosh HD:System:Library:Fonts:HelveLTMM”.
Font: “.Aqua Kana” Style: “Bold” File: “Macintosh HD:System:Library:Fonts:AquaKana.ttc”.
Font: “.Aqua Kana” Style: “Regular” File: “Macintosh HD:System:Library:Fonts:AquaKana.ttc”.
Joe2
(Joe)
September 12, 2011, 3:07pm
10
I think this might be a bug. I’ll get it logged. Unfortunately it seems to be happening with all the sans-serif Arabic fonts I can find so I can’t offer a solution right now.
Font Problems
