i have a text which is longer than the size of my page so i set it to auto in order for it to scroll and show the part which is beyond the page’s lower limit. the scroll bar appears ok but the text which is below the page’s limit does not show.
does anyone have any about how to fix it? would putting the text in a frame solve it?
thanks.
Hi Edson
Can you post a link to your online page so we can see the problem.
But of course you can just make the page longer to accommodate it.
hi david,
this is a trial page for my office: http://tinyurl.com/y8zzrac. thanks.
problem solved. it was a matter of reducing the size of the HTML item to stay within the page.
Or increasing the page length to accommodate the HTML item
