I upgraded Freeway Pro to 6.1.0 and ever since I cannot upload any of my sites to Fat Cow. I get the error:
“Cannot complete the upload because the user or password is incorrect. (530 login incorrect)”
I can still login to Fat Cow using my normal login and password so I don’t believe the problem is there. Nothing has changed with my account at Fat Cow. Only gone wrong since I upgraded to 6.1.0.
Any thoughts? I desperately need to update some of my sites!
I would start afresh and completely remove anything in all the FTP upload fields.
Do this by clicking in each field and Cmd + A to select all and delete.
Then very carefully re-enter everything, double checking as you go.
If you then still have a problem then try toggling the Mode ie if Auto try Passive etc
Thanks David. That worked. Never needed to that in previous updates. Strange.
Cheers,
Neil.
