[Pro] Problems with IE and Freeway 5.5 Slideshow
Hi! I love the new photo gallery slideshow program in 5.5. It does everything I want it to do.
However, when viewing on Internet Explorer on a PC, the thumbnails show up but when you click on them it doesn’t render the larger versions like is should. Doesn’t show them at all - it’s as if it stalls.
Is this a PC thing? IE thing? It works fine in other browsers and on my Mac. But since most people still use IE on a PC, I would want it to display properly.
If anyone has any suggestions or fixes, it would be appreciated.
Thanks!
I’m not trying to be unhelpful but I haven’t experienced any problems viewing the slideshows and galleries in IE 8 of Firefox (Vista or XP - running under Parallels). I have six galleries each with five to 30 pictures. Everything works as expected - perhaps I’m doings something different to you.
What version of IE and what operating system?
There’s an issue that’s been fixed internally - to fix it make sure that the Large Image Border is set to a color, not none. The border size can be 0 so no border will actually be visible.
That’s it!
We’re on the latest IE on our PCs at work (which is where I test the PC version, as I’m on Mac here at home). I think it’s IE 8.
Thanks Joe! I’ll make that change in the borders and see how that works.
I’ll let you know - but not until tomorrow when I’m back on a PC at work. :slight_smile:
Thank you! I checked and that adding a border to the large images worked perfectly.
Glad it was an easy fix. Thanks again!
