I’m trying to make a rollover navigation menu with Layer Show/Hide action.
I wish to show the first submenu on page load, so I set this layer as “Initially:Visible”. If I set for all the instances in the same chain to sticky option, the opened submenu is still showed even if I rollover to other menus.
P.D.:I found a workaround setting the first layer as hide in the action palette and extending the body with onload:“FWSlave(top.frames,‘Indigo’,1,1)”… It’s not too clean, but do the job!
Ooooops!!
I thought I have erased the uploading info… Anyway, file removed and user and password changed! Although I’m sure your webpages would be better than mine… ;-p
Thanks for the tip!
In fact the web I’m working on is not based on images. All are text boxes which I have extended with an onmouseover event to work as rollover items.
But the problem -or question- I’m asking for is about the method to make the proposed menu without tricks.
