Hi the experts,
I’ve been asked if I would be able to do a product configurator and my simple answer was “No - not really”. However there’s always the weird feeling of “simply No is easy but not really the best”. However I haven’t any clue on how to near the theme. I’d like to ask you, if you probably have experience with that theme and what you could advice me to do.
Ideally the Configurator should work like:
Input some measures like
width x length x hight the customer wants (text field?)
Choose a value like 0 or +20
Choose a material
and get prices for each step (just like probably the apple configurator).
The first and easier way I thought is probably a simple form as a quote request but the idea of renewing a price each step is too attractive.
It should be mentioned that I try to make turnover with a possible solution (script) - so there’s no doubt that I’d pay for it if there’s any solution out there or ideally is coming from you.
Thanks for any suggestion in advance.
dynamo mailing list
