[Pro] Protaculous 2
Hi Walter,
I have a slight problem with this action combined with the ScriptyFader Suite. Each time I publish/upload the site since having installed Protaculous 2 Action, every page in my site that uses ScriptyFader gets rebuilt and re-uploaded even if no work has been done on it.
If, for example, I publish and immediately re-publish (not something I normally do but just by way of an example) all pages with ScriptyFader applied receive a black bullet in Site Folder and get re-published. Strangely, all pages that use the ScriptyFader Action do not have Protaculous 2 applied to them.
The example link is a page that uses ScriptyFader/Option/Thumbnail Action but with no Protaculous 2 on the page.
It’s not a mega problem, just a bit time consuming and bandwidth sapping. Not sure if this is what to expect each and every time.
Protaculous 2 Action v 1.1
ScriptyFader v. 0.6.1
ScriptyFader Option v. 0.6.1
ScriptyFader Thumbnail v. 0.6.1
Freeway v. 5.6.5 & v. 6.1.2
Regards, David
http://www.aircushionboot.com/SolovairYellowStitch8EyeBlackBoot.html
Are any of these Actions applied to master pages?
On Jul 14, 2014, at 6:14 AM, David Murray wrote:
Hi Walter,
Thanks for your response Walter.
Yes and no, the pages where ScriptyFader is in use uses a different master page to the pages where Protaculous 2 is applied. So the pages that use the master to which Protaculous 2 is applied do not have any ScriptyFader in use.
I have not applied ScriptyFader on any master page finding it more controllable to use it on a page by page basis, (probably erroneously).
No, this is how I use it as well. These effects should not be used widely – they are the cherry on top of the sundae, not the meal.
See if you can build a cut-down site that shows this problem. Ideal for me would be if you can get the site to not re-publish, and then add one thing and suddenly it re-publishes all the time. It’s very difficult to diagnose these Action inter-relations, particularly if you get into the realm of external stylesheets and my style-override code. That is a pain point, and ScriptyFader uses that, and it may be difficult to fix. See if switching to use inline stylesheets makes any difference.
Thanks again Walter.
I have just deselected ‘External stylesheets’ and it would appear initially to not require a re-publish each time. Many thanks for that!
As a matter of interest what are the arguments for and against for inline or external stylesheets? When you have a moment.
