[Pro] Publishing every page
I seem to be having a problem with 5 wanting to publish every page on websites even when I don’t touch that specific page. I can go in to make a type change to one page on an 65 page site with numerous pdf’s and it uploads everything as new including the pdf’s. Any clue as to what I am doing wrong?
Thanks, Clark
Every now and then I found I was republishing at least 50% of my sites,
regardless of the change made to the site.
Since all my resources are kept in the same folder, that can amount to a
lot of items, and I found the server was only allowing 1,998 items to
show in the folder on the server. This was because the default settings
were to only show that amount. All the resources were on the server to
be accessed by the various web pages but when the Freeway FTP program
looked at the server it only found 1,998 items in the resource folder,
consequently everything beyond that point had to be uploaded every time
even with a minor change to one page.
The problem was solved by having the hosting company change the default
on the server and then only the actual changes had to be uploaded. I
would suggest you contact your hosting company to see if by chance the
server is set to only recognize a specific number of files.
I found the problem by examining the various folders on the server using
Fetch and compared the actual stored files against the site folder on my
system.
Hope this helps.
Andy
Thanks, Clark
Certain actions can cause this - what if any are you using - it may be one of them.
