Is it possible to do something similar to what Cracker Barrel has done with their pull up ads at the bottom of their home page? This is a really cool feature and I can see myself using it frequently.
http://www.crackerbarrel.com/
Thanks!
Transition FX action
Really? Very cool.
I can’t find Transition FX. Is that the same action as suiteFX?
waltd
(Walter Davis)
May 11, 2012, 7:38pm
#5
It’s a built in Action, added in Freeway 5 or 4, can’t recall which.
Awesome. Thanks Walter.
Not sure I understand how this action works. Is there a tutorial someplace that explains how to set it up?
Also, why does Applescript have to be enabled to use Transition FX and will that cause any issues with any web browsers?
Applescript has to be enabled so that actions can write their code into your page. This has nothing to do with web browsers as it is the process whereby your page code is written and nothing to do with how a browser displays your page.
Thanks Dave. Unfortunately, I still can’t seem to figure out how Transition FX works. I did everything per the FWP 5.5 Reference Manual, but I can’t seem to get the same kind of effect from the Cracker Barrel website.
Do you happen to have any examples?
Delving deeper into Transition FX it appears that it cant do what you want.
The closest I have come using script/protaculous is at http://www.deltadesign.co/fw_examples/protac/move-up.html but this needs a bit of tweaking to get it right.
Still playing with it
Thanks for your help Dave.
I’m still trying to figure this out. Dave has been extremely helpful, but we’re not quite there. Any suggestions?
waltd
(Walter Davis)
May 14, 2012, 10:05pm
#14
Something desperately wrong with your page. Note how you have 5 instances of builder.js in your page. Look at your source, scriptaculous link is tailed with ?load=builder,builder,builder,builder,builder,etc.
Check the Protaculous version, please tell me which one that is. What are the other Actions on the page?
On May 14, 2012, at 5:58 PM, DeltaDave wrote:
Version 3
http://www.deltadesign.co/fw_examples/protac/move-up3.html
Observer 0.3.2
Protaculous 0.7.2
Thats it
waltd
(Walter Davis)
May 14, 2012, 10:42pm
#16
Please send me that document.
Observer 0.3.2
Protaculous 0.7.2
Thats it
On its way
RavenManiac
(RavenManiac)
September 15, 2012, 10:14am
#18
On 14 May 2012, 9:58 pm, DeltaDave wrote:
Version 3
Dave, how do I implement this in Freeway Pro? I understand where to place the Page markup - Before code, but where does the rest of the code go and how do I insert it into FWP? Crowbar perhaps?
Thanks!
Page>Html Markup (code on the example page) in the before section
Protaculous action attached to the page (scriptaculous-packed) code on the example page in the top function body section
The Observer action is attached to each Tab (code on the example page) and each tab is specific to itself ie tab1 tab2 etc.
Each Tab is a child of a Div called shell
No Crowbar!
RavenManiac
(RavenManiac)
September 15, 2012, 3:26pm
#20
So in laymans terms, I should design each tab in a separate HTML or graphic box and use FWP to adjust the size and margins for each?
