I have used a lot of different hosts over the years.
- Modwest
- A2Hosting
- Dreamhost
- Joyent
- Rackspace
I would say that A2 are probably the nicest in terms of support, although that’s probably a tie with Joyent.
Joyent is for the big jobs, though; you won’t find anything smaller than a 1GB VPS (Virtual Private Server), and they expect you to know how to compile your own software as root.
When your client is paying, and your client expects the site to be live always, then Joyent is the first place I would look and Rackspace a close second.
On Oct 29, 2011, at 1:17 PM, Chris Jones wrote:
Problem solved: it was “a problem with a temp file on our server…” Go figure.
I am inclined to agree with you about GoDaddy, and yes, I think their ads are sexists and stupid as well.
However, they do answer the phones quickly, they never treat me as stupid (as the other host provider did when I last tried to switch) and they always figure things out, which they just did after a 5 minute phone call.
If it were not such a hassle to migrate, I would do it in a skinny minute. Or perhaps just begin all new projects on a new server.
Is there a host that you can suggest-- that won’t treat me as stupid when I call with a question? and please don’t suggest fat cow. been there, done that.
