“Javascript code provides a better performance for your website. It is the recommended way to embed ChatWing into your website. You will not need to update the code in your website after changing the options”
I often use iFrames so that updates and maintenance will be done
automatically on ‘the other side’. But I don’t know Chatwing. If it works
better when its embedded then the choice is clear.
Op 16 dec. 2014 16:02 schreef “Hoffkids” email@hidden:
the designer of the box says
I vote the same way as Richard, whenever it’s feasible to avoid iframes, it is best to do so. They are finicky (especially on responsive websites) and you can’t customize their content with your own CSS if you chose to do so. They also slow down the loading time of the website, as your browser is having to fetch two complete pages.
