[Pro] Quick Time Movie problems
I am having difficulty in getting Quick Time movies to function properly or to even launch at all in the newest version of Freeway. I had them working perfectly in the earlier version. I have just been dragging the files onto the page and when I preview them they work just fine. When I upload them they work fine on my new iMac but not on any PC’s.
Any ideas as to what could be the problem?
Here’s a page link:
http://www.cycloneproductiontools.com/cycloneproductif.html
Thanks in advance!
Clark
Hi Clark,
Your movie has been encoded using DivX. I haven’t installed the DivX
component on my Mac so it doesn’t work for me either. The best thing
to do would be to recreate the movie (or convert it) using a different
encoding. QuickTime Pro will do this for you (an optional install on
Snow Leopard).
Hope this helps,
not on any PC’s.
Here’s a page link:
Thanks in advance!
Clark
