Hi -Years ago I created this site with Freeway Pro ver 5.5.
The client no longer has this business, but I still want to showcase on a website.
I am able to use an iframe to show the content, however, when viewed on tablets, mobile devices it does not scale down to fit.
I don’t want to update this to version 7 and have to mess with anything. I want to spend the minimal amount of time possible to just it it to scale accordingly. I don’t need CSS responsive menus or anything.
Is there an easy way to get it to be responsive? The site where I want to put it is responsive, and also has a responsive iframe plugin.
http://tinyurl.com/lgwlelp
No - not an easy one.
The Advanced iFrame WordPress plug in you are using does allow some leeway because you are hosting the Pilates pages on the same server but this is not really a FW question.
I think you would be better to explore the capabilities of the plugin or its Pro version if you dont want to redo the FW pages.
ok- thanks. Just thought there might be some code that could be added to the html freeway site. to make it scale.
If only it was that easy!
