I have culster of radio buttons in a Form to select 1 only from a choice of products but when I add the Mals Quantity/checkbox/radio action to the radio buttons I loose the “only one selected” mode.
Hi Trev,
Make sure that the product numbers in the actions palette for all of
the radio buttons are the same otherwise the action will create a
product for each of the unique product numbers. If, for example, you
have a choice of three items then make sure they all have the same
product number in the actions palette and when then the form is
submitted only the selected item will be added to the cart.
If you get stuck get back in touch with a copy of your Freeway file
and I’ll take a closer look.
Hi Tim
Thanks for the fast reply.
I have made all the radio buttons in the cluster the same product number but reporting “ERROR: Link verification failed” on submission.
Hi Trev,
Can you send me a copy of the Freeway file please (or at least the
page you are having problems with copied to a new Freeway document)?
I should be able to see what is going wrong on closer inspection.
On 11 Aug 2010, at 17:50, t50ufo wrote:
Hi Tim
